Heater temperature stopping | on ElectriciansForums
Discuss Heater temperature stopping in the UK Electrical Forum area at ElectriciansForums.net
J
jimjim2991
Using to a heater to heat 5L of water.
1. How can I stop this heater at 70C without a thermostat?
2. Will a potentiometer work?
More info required.
As above...
Have you already got your heating element and equipment?
Not that I know a lot about heating elements but these just look like there are different wattage/sizes of heaters. Nothing about heaters that switch off at 70C
Whatever you do, don't just wire a potentiometer in series with your element!!
As said above, you need a sensor/thermostat of some sort. Why do you specifically not want to use a thermostat? This is the sort of job they are designed for!
You can't heat to a specified temperature without a thermostat. (well not quite true you can heat to 100 degrees C as the water just boils off at that)
If you know the starting temperature of the water, the heat loss from the vessel you could approximate the right temp with a timer but that's very rough...
You would need to factor in the starting temperature of the water, ambient temperature of the room.. impossible to be anything like accurate.
Reply to Heater temperature stopping in the UK Electrical Forum area at ElectriciansForums.net
Hello All, This is Vaithees from India. We are using an IR heater for a vacuum & non-vacuum chamber and got a heater from Chinese company and its...
Thank you for the suggestion!
