Discuss Heating Engineer set me a challenge in the Central Heating Systems area at ElectriciansForums.net
Piece of cake .... Hacksaw through that 22mm pipe just as it enters the elbow making a vertical cut, then drag the elbow with the pipe attached to the right and forwards away from the plug.
Remove plug from socket and leave the plumber to clear the wreckage .......
And don't forget to kill the power before unplugging, what with all that water everywhere!
A good bit of forward thinking by our plumbing community again lol, did you pass?
Is that a pubic hair stuck to the plug or is it cracked. If it's a pube you could probably identify the plumber with a quick DNA test
Also that soldering is atrocious
I didn't see the need to mention that.
EVERY spark carries-out Safe Isolation as a matter of course innit???
Reply to Heating Engineer set me a challenge in the Central Heating Systems area at ElectriciansForums.net
