Heatrae Sadia multipoint 50 issue? plumbing advice | on ElectriciansForums
  • Thread starter macka09
  • Start date
  • Replies 0
  • Views 49
Discuss Heatrae Sadia multipoint 50 issue? plumbing advice in the Plumbers Forums area at ElectriciansForums.net
Heatrae Sadia multipoint 50 issue? Hi folks
I’ve never installed or maintained the water heater above but today I’ve isolated the cold into the heater but lived up the mains to it so that it could feed the other appliances.
I noticed that water was passing through the tundish. As id isolated the feed into the heater I ruled out the temp/prv on top of the unit being the issue. I checked the vessel which was flat and full of water, so I replaced it. Still water passing through tundish. There was also a prv fitted on the feed to the unit so I assumed this was the issue. Changed it and still passing.
What I did notice was there was no pressure reducing valve fitted. I didn’t have my gauges on me to test the incoming but am I right in thinking that if the heater is isolated it clearly can’t be the prv on top and had to be the prv on the incoming feed due to high pressure??
I will be checking the incoming pressure but the fact theirs no pressure reducing valve I’m assuming the incoming must be opening the 6bar prv!
Anything I may be missing here?
Heatrae Sadia multipoint 50 issue? to read more on the original thread at Plumbing Advice
See also UK Plumbing Advice for all UK plumbing advice needs.
Reply to Heatrae Sadia multipoint 50 issue? plumbing advice in the Plumbers Forums area at ElectriciansForums.net
T
PRV with Gauge Question Hi, I have a Caffeli PRV near the mains stopcock. Static pressure fluctuates between 3-4 Bar and when a tap is opened it...
techweb
T
L
What could be causing this noise in the tundish? Hi all, anyone know what could be causing this? Everytime I flush the toilet the (what I think is...
Lawsofpower
L
