M
mcfcdwa
hi there i need to know if there is a regulation height for a double socket in a building re-furb and if there is a max distance to run a 32 amp ring main for them, thanks all
I see what you mean. Well, you CAN do if you want but you are not required to. We can't dictate. Only as stated no worst that existing and not if plug or flex would damage under use.I was recently asked to quote on a rewire, the original wiring had sockets at various heights, now the above wouldnt apply surely in this instance, as how could you walk away from a job that you've just rewired, that has sockets in the same room with varrying heights, i mean one at 250mm then one at 400mm den another at 200mm surely in situaions as such we should all be bringing the new sockets to a standard height of 450mm or would that be asking for too much.
I disagree with that aspect, firstly not only does it not look too pleasing asthetically but it defys the whole idea of the requirements of access for disabled individuals, so as we are all competant people we surely need to make this a point when doing rewires.
I would agree that if we are only changing, or adding to rfc then we can play with the heights but as its a complete rewire i would think that it would require adjusting accordingly.
The point being made here though Mad is that if its a rewire of an EXISTING installation then you dont have to site accessories in the 450-1200 band.....but as for aesthetics....then yes it would be better to have all fronts at the same height....when my boss n i undertake a rewire we site accessories within the 450-1200 band...but you dont have to as far as compliance is concerned......another thing is when survaying the job is to see if the client/s are elderly or disabled and you can suggest this to em as i would suspect that most people not electrically minded will be unaware of this.........I disagree with that aspect, firstly not only does it not look too pleasing asthetically but it defys the whole idea of the requirements of access for disabled individuals, so as we are all competant people we surely need to make this a point when doing rewires.
Its not what the customer say or doesnt say, its up to us as designers of the installtion to have pride in our work and to do that little bit extra to make sure you are happy at the end of each night.
I have read the regulations cover to cover on a number of occasions and yes it doesnt say that in the bgb and the brb but the poiint still stands that asthetically how could u walk away if on the same wall you have sockets that are at diff heights.
If there was a purpose for the socket to be heigher or lower then the rest (ie for a flat screen tv), then its understandable, but as a rule of thumb I think we ought to be asking/telling our customers to be standerising heights.
you can tell instantly who`s who..in the deep pocket situation....but as i see it..it doesn`t matter either way....the standards of work/install....together with all relevent tests and the paperwork to back it up should be consistant.......this is what gets my goat about cowboys......Totally agree fuzz, however i feel what I'm saying is still relevant, yes the customers are all different some have very deep pockets, and some have very tight purse strings, so we are in a bit of a nightmare scenario, but we have to try.
For me anyway, every rewire I have done to date I have spend extra time and effort in bringing sockets/switches to the new heights.
it has taken a bit of persuassion on the my part but when i mention what needs doing to the customer, they luckly have agreed without much hesitation.
Reply to the thread, titled "height for sockets" which is posted in Australia on Electricians Forums.
