Hello from Leeds | on ElectriciansForums
Discuss Hello from Leeds in the The Welcome Forum area at ElectriciansForums.net
Leeds/UK
Hi from Leeds!
I'm an interested hobbyist really....not qualified in any way....apart from an A-level in Physics from waaaaay back in 1975.
Re-wired the (then) marital home back in the 80's...and always took good advice from Pro's! :)
Hoping to get some ideas on why a 13 month old Hotpoint Combi oven (Yes....guaranteed for 12 full months...HaHa) might be tripping the MCB at the box. This doesn't appear to happen when Microwave is selected.....but seem to happen when Fan assisted oven has been running for 15 to 20 mins.
I'll also post in a relevant section of the forum
Ta!!
Most likely the element at the back, round the fan.
Especially if you use spray oven cleaner. The spray goes through the grill, lands on the fan and then drips on the element below.
Most oven cleaner is highly corrosive and it eats away at the element until it lets moisture in and then trips the rcd.
Thanks for getting back...that was quick!!
The oven is stainless steel inside...and as such has only been wiped....it's pretty clean!
Haven't used any spray cleaners....
If it was the element....can this be tested....or just look to replace it??
New element about £40
can be fitted your self if you are confident.
Call out someone to diagnose it is probably 2 x that cost
95% of the time it is an element, 60 to 70% it is that particular one.
your call
your call
Right!!....so just to be clear...we're talking about the kettle 'type' element that is attached to the 'roof' of the oven?? (Not some other element....(almost typed elephant there)....Oh I DID type elephant!!)
No, on a fan oven, there is a circular element that is wrapped around the fan, take the back panel off (inside the oven) and you will see it
Reply to Hello from Leeds in the The Welcome Forum area at ElectriciansForums.net
I saw an interesting video on u-tube on this subject, seems the oven heating element had a split in it and it took about twenty mins for the trip...
Hello - Looking for assistance regarding a problem with my three way switch what was working over the past four months with no problems until this...
Some of the points should have been picked up by previous people doing the testing. Sounds like this is a thorough report. Not everything is...
Hello everyone, thanks for this nice forum! I'm looking for some raw logs of RS485/Modbus communications between an inverter and its smart meter...
Deleted member 147397
Nice one, thanks for letting us know.
8K
