Help!!! Can't turn electric off!!! | Page 2 | on ElectriciansForums
Discuss Help!!! Can't turn electric off!!! in the UK Electrical Forum area at ElectriciansForums.net
Doug81
Nottingham
Hi, I'm currently in the process of changing all my switches and sockets and I'm coming across a few problems, like no earth wire for any of the light fittings. Similarly no earth for some of the upstairs plug sockets but the worst yet is the socket in the hallway (right by the fuse box). It has both new (blue,brown,yellow/green) and old (red,black) wires looped together -not a big issue I hear you say....well it is when the old wiring is live even when the fuse box is switched off!!! How do I go about making it safe???
[ElectriciansForums.net] Help!!! Can't turn electric off!!!
So are you saying you had the main switch (the big red one on the left) switched off yet those wires were still live?
There was never a socket fitted to that backbone, there's too much plaster, there's only one (new) cross head screw holding the back box to the wall also.
The red and black cables look like the outer insulation doesn't enter the back box (which also looks too shiny to be any thing other than new.
What's the large black box on it's side under the meter, is that grey T&E with white tape connected to it?
I suspect we're not getting the full story here.
So many unanswered questions! I wonder if I go to bed I’ll dream of the answers -
I hope not!
The walls were skimmed
The walls were recently skimmed with the socket fronts unscrewed from the wall, that's why there is excess plaster in the corners. See close up pics....hope this explains more??
It's all back on now but I switched the main red one off on the left. What do you need to see in the pic?
The red and black there is still live when the fuse board is turned off?
You have a serious problem.
How did you test that? Sore fingers?
Can you post a photo of your meter and fuseboard set up. There might be a clue as to what is wrong.
Can you safely protect those live cables from accidental touching?
How did a socket fit on that box with all that plaster taking up the top right corner?
Anyone in Nottingham up for a late night Saturday night callout?
The box under the meter may be a bell transormer that could (if the labelling is correct) be connected to the MCB that is taped off.
If, with the main red switch in the off position, the cables coming out of the wall are still live, then you should seek the services of a competent local electrician immediately.
Reply to Help!!! Can't turn electric off!!! in the UK Electrical Forum area at ElectriciansForums.net
If the OP could DM you with that info? Rough area is fine, but don’t post your full address in public, obviously.
Power off ! The switch wires will be the ones that go low resistance when the switch is turned on and go open circuit when its off.
