Help!!! Can't turn electric off!!! | Page 3 | on ElectriciansForums
Discuss Help!!! Can't turn electric off!!! in the UK Electrical Forum area at ElectriciansForums.net
Doug81
Nottingham
Hi, I'm currently in the process of changing all my switches and sockets and I'm coming across a few problems, like no earth wire for any of the light fittings. Similarly no earth for some of the upstairs plug sockets but the worst yet is the socket in the hallway (right by the fuse box). It has both new (blue,brown,yellow/green) and old (red,black) wires looped together -not a big issue I hear you say....well it is when the old wiring is live even when the fuse box is switched off!!! How do I go about making it safe???
[ElectriciansForums.net] Help!!! Can't turn electric off!!!
The box under the meter may be a bell transormer that could (if the labelling is correct) be connected to the MCB that is taped off.
If, with the main red switch in the off position, the cables coming out of the wall are still live, then you should seek the services of a competent local electrician immediately.
Any solar panels?
Nope
I'm just wondering why there's a red and brown wire coming from the service head going to meter and why is there a grey sheathed cable into the earth Henley block? Where does that go?
Believe or not the brown tail is the neutral by the looks of it. Incredible!
The grey tail is the TN-C-S link between earth and Neutral even though it is also set up as a TN-S. I’ve seen this twice before.
Reply to Help!!! Can't turn electric off!!! in the UK Electrical Forum area at ElectriciansForums.net
If the OP could DM you with that info? Rough area is fine, but don’t post your full address in public, obviously.
Power off ! The switch wires will be the ones that go low resistance when the switch is turned on and go open circuit when its off.
