HELP! Fire alarm problem, tiny fuses, much frustration! | Page 2 | on ElectriciansForums
Discuss HELP! Fire alarm problem, tiny fuses, much frustration! in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
I had a similar problem with break glassunits many years ago. If you can check to see if the smoke detectors activate at a resistance or a dead short?
The fault i had was the call points put a dead short on popping fuses The panel would activate if a 125k resistance showed up on the N/O detector circuit.
Would like to make sure we get it right before buy more detectors which could be wrong, are the sirens part of the base or seperate. and is this the panel...otherwise suggest some photos tomorrow and we will then know what you have
That looks closer to what I have, but still not quite. I will try and get some photos today.
Yea the sirens are seperate from the detectors.
Thanks for all your help so far. I hate alarms. I hate them.
Okay, in the above post, we have 1. the existing base 2. a sounder within the circuit 3. the panel 4.inside the panel 5. the last sounder in the circuit with the little resistor 6. my new base 7. my new detector. 8 is a repeat but should be the existing detectors (which ARE appollo s65 optical smokes).
Any ideas?? Cheers
OK cool, thanks. If I wire them like this, will I then be able to use my detectors, or will I still have to get the apollo sav ones?
Just to mention - I have bypassed all of my detectors so that the system is as it was before I started, and it works fine like that (even with the incorrect wiring)
Oh also, is it possible for me to turn this zone into a 2-wire system or whatever? I.e. buy the diode bases for the existing detectors, and use my detectors alongside them? It would certainly be cheaper that way, but can it be done on this panel? Thanks!
Ah see you answered my question before I asked it!! I'll check out that link... thanks so much for all your help, you are a lifesaver!!
Reply to HELP! Fire alarm problem, tiny fuses, much frustration! in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Thank you all, yes I didn’t think they do and I have done minor works but the helpline was not very helpful. Got my yearly assessment soon so I...
hi yes i agree its a final pir circuit with 30 seconds entry and exit programmed in no other detectors on route to rkp tried a different...
