Hi lads ,
I’m interested to run a SWA cable on my garden for my small one bedroom flat.
I have planned to use 100amp double pole 3 way connection service block after the meter , then I want to use 63 AMP double pole RCD in metal enclosure and from there to run my 6.0mm SWA armoured Cable up to my flat where will be installed new CU with shower, radiator, ring and lighting .
The distance from my house to the flat is around 80 meters.
My question is if this is right and comply with regs ?
