Help for running SWA cable | Page 2 | on ElectriciansForums
Discuss Help for running SWA cable in the UK Electrical Forum area at ElectriciansForums.net
London
Hi lads ,
I’m interested to run a SWA cable on my garden for my small one bedroom flat.
I have planned to use 100amp double pole 3 way connection service block after the meter , then I want to use 63 AMP double pole RCD in metal enclosure and from there to run my 6.0mm SWA armoured Cable up to my flat where will be installed new CU with shower, radiator, ring and lighting .
The distance from my house to the flat is around 80 meters.
My question is if this is right and comply with regs ?
Sorry but closing this thread, what your asking and wanting to do is beyond DIY, as a forum we have to offer the correct advice with safety in mind and also the regulations surrounding it, this is not a task you should be doing without onsite professional guidance and testing with signing off. If you have any issues please PM me.
Reply to Help for running SWA cable in the UK Electrical Forum area at ElectriciansForums.net
You would treat it as a TT installation.
And if it's a garage then use metal clad accessories.
