Hi - hope someone can help.
First, quick bit of background. I clean ovens for a living and have a tank in the van for cleaning oven parts. It has a regular 240v imersion element in it which I heat up each morning.
It's connected to an 13a extension cable which is plugged into an outdoor socket.
The outdoor socket is connected to a plug socket inside the house (I drilled through the wall and plug the socket into the household socket. Not ideal, I know. But have been advised it's safe).
Now as I'm lazy I fitted a wifi plug so I can turn it on from bed. It was on for about an hour each morning. I have left it on all night by accident a couple of times, it the element has a thermostat, so presume it wasn't running constantly.
Checked the plug his morning and discovered that it had been getting very hot and had melted the plug to the socket. Everything worked, and nothing had tripped.
Anyone know the likely cause?
