Type B RCBOs are used where there is PV.
So they will become more common place, as more homes get PV.
I believe also, that they are required for vehicle charging points?
They are only required when the DC residual current component exceeds a certain value (6mA springs to mind)
If the PV equipment or charging unit has built in protection to prevent a DC residual current then a type A RCD is ok.
And that's the extent of my knowledge on these areas so can't go in to any more detail
Help!!!! Metrel Mi3000 tester problem
Electrical Tools and Products
junior-sparky,
davesparks,
