Help need to change ceiling light | Page 4 | on ElectriciansForums
Discuss Help need to change ceiling light in the The Welcome Forum area at ElectriciansForums.net
I thought the light was in zone 3.
It's the downstairs bathroom and in the few years I've been here I've only showered a couple of times in it, it's mainly used to was the dogs and guests can use it to 'off load '
Now I can wire it correctly I had better get a zone 2 light then I suppose. Better safe than sorry.
Can anyone advice me as to where I connect the wires from the single light into the new chrome light. On the chrome light there is a connector that has three openings but the old single has wires coming out of four different holes .On the chrome there is L E N.On the old one the 3 L get fed into one hole two black get fed into a hole and a single black gets fed into a hole. The E gets fed into a hole just above the rest of the wires (see photo )
Re-read the responses from Westward carefully all the information you want is there.
Reply to Help need to change ceiling light in the The Welcome Forum area at ElectriciansForums.net
Power off ! The switch wires will be the ones that go low resistance when the switch is turned on and go open circuit when its off.
Any professional forum member in or near Somerset help out? Needs a little more help than we can offer from afar.
