Help needed am2 exam coming
Hi all,
Just wondering if anybody has any infomation that could be helpful as i am taking my am2 in the next couple of months.
Many thanks
Simon
Hi
I passed my AM2 last weekend and the biggest piece of advice I can give is try not to panic, even if the assessor notices you've made a minor mistake. I actually felt that the two assessors were very helpful and sometimes even gave you a nudge in the right direction. If you know your stuff you relax into it after the first hour or so.
Read the specs carefully, they give mcb types and conductor sizes. The single core CPCs are usually smaller than the line conductors.
When doing the S plan just follow the wiring diagram. Also remember to install any link cables such as in the programmer (again, its all in the diagram)
Dont attempt to rush the whole installation as you will forget to do the basic things properly, but also bear in mind that there is a countdown timer over your head and believe me that time really flies by, so try to be focused and organised.
As for the fault finding I actually found this quite easy and stress free as long as you know your stuff and follow the methodical testing process.
For each fault start at the DB and work towards the fault using a continuity tester until you get something unexpected. Jackpot.
For example with the intermediate lighting start at the mcb then to first switch then to intermediate then to last switch then to light, all the while conducting continuity tests which will show up as shorts (if there is one) or high resistances (poor terminations, corroded, damaged cable) Insulation resistance testing at the DB also is a big indicator if the circuit is healthy.
If your centre is busy the assessors will not be watching you the whole time they will just put the fault on and leave you to it, so theres not the added pressure of him looking over your shoulder.
Good Luck Mate.
Upvote 0
Hi Simon,
Not sure if you have sat your AM2 yet? If not I sat mine 2 weeks ago and luckily managed to pass 1st time. I have quite a bit of info on it if your interested (or anyone else).
Let me know and I either post or PM me and I will email you the info.
However the most stressful bits was the fault finding, there are 7 faults (you have to get 5). Mine were
1. RCBO keeps tripping. Ring Main - Short circuit between Neutral & Earth. You have to tell them between what two points, how you would rectify, and the tests you would perform to ensure the fix.
2. Light circuit not working - No continuity on neutral, again between what points, fix and test(s).
3. Motor not working - No continuity on neutral from CU to starter. Again fix and test(s).
4. Data fault short between pins 7 & 8. in your pack you will have the user guide to the test meter. This will show a list of all the faults the unit can detect with what lights up for each fault. Again fix and test(s).
5. Gas bonding - reading was 2.58 ohms. Not within the 0.05 ohms expected. Again fix and test(s).
6. 16A 3 phase socket had low IR reading, from socket back to isolator. Between all phases and Earth, also between All phases & neutral. Again fix and test(s).
7. CH not working although programmer calling for heat and room thermostat calling for heat. I had no continuity from Room thermostat L2 to pin 14 (i think) on DIN rail. Again fix and test(s).
Follow the spec in the pack and you should be ok. If during Test and Inspection you find any problems, you are allowed to fix.
Don't panic with the S plan. It is the easiest part of the install. Point to point and lots of it is pre-wired allow at least an hour. They do require you to use ferrules on the flex cables as easier to push into the DIN rail.
Good luck hope this helps.
Hi just read your details... I’m due to take my AM2. I would be great full for any information you may have ..kind Regards Rob!
Upvote 0
Hi Simon,
Hi Simon glad to hear you passed 1st time. Is there any chance you could send me over any information you may have, would really appreciate it!
Upvote 0
Hi Shane,
If you send me your email I will forward what I have across to you. I have also changed my personal settings (I think).
Hi would it be possible for you to send me any information you have on the AM2 as I have got mine in a couple of weeks. Would be so greatly appreciated
Post automatically merged:
Hello mate can you please send it to me thanks
Upvote 0
Electrical Courses
