help needed for fault on lighting circuits | Page 2 | on ElectriciansForums
Discuss help needed for fault on lighting circuits in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Test it properly. R1+R2 then IR, this should show up any faults if you do it properly. If you don't test it methodically, you will spend all day chasing your backside.
Cheers...............Howard
With respect, neither R1+R2 nor IR will pick up a high impedance on the neutral, unless I'm missing something? Which maybe he has here, I'm not clear what is going to 78V though.
Reply to help needed for fault on lighting circuits in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Any electronics in circuit that might be skewing the readings? Smokies. Or smart switches? Might have been covered already, but what about...
Fitted a lot of this sort of light recently, with all tests reporting back through central Dali controller(s).
nicebutdim
N
