Help needed. Garage wiring | Page 5 | on ElectriciansForums
Discuss Help needed. Garage wiring in the DIY Electrical Advice area at ElectriciansForums.net
Oh would ya look at that
If this is the standard of work you are happy to show off then I dread to think what the rest of it looks like.
Just some brief points, as you wanted to learn the "art".
  1. There are gaps which allow access to live parts
  2. The ordering of protective devices is wrong, it should go from highest to lowest.
  3. Looking at this I can't tell if there is supposed to be a second main switch? If so its clearly missing.
This is just looking at it from the outside.
Some manufacturers would beg to differ, they recommend that the MCBs are arranged between heavy and light loads to reduce thermal and magnetic influence.
So here we have a rewire to a garage, by someone who apparently has no idea of what type of earthing system he has, or whether it it’s compliant or even adequate or what bonding is required, can’t or won’t check or calculate resistances or probably doesn’t know why he even should do, or what they would mean if he did measure them, who intends to use a 150A welder, (presumably 16A supply required and are surge currents an issue?), and to boot is (in my opinion and I chose this word carefully) ignorant. I read this thread with interest hoping to learn something. I’m not disappointed.
I think it best for all concerned if this thread is locked before any more damage is done, as it appears to have become a bait fest
None of my business really, but I do hate it when people are unnecessarily rude (This implies that there are situations where it necessary to be rude, perhsps when someone is just about to injure themselves or another because they’ve done something dangerous or stupid)
Am I being a pompous g*t?
...and inspected and tested by a qualified electrician, whom was more than happy with the work i had done.
If this is true then everything is fine and dandy.... No need to worry about anything.....
Reply to Help needed. Garage wiring in the DIY Electrical Advice area at ElectriciansForums.net
Why go to the trouble of adding another cable, which I assume would follow the same route as the other ?. Why not upgrade it. It was to try to...
thank you so much. that worked out. i ended up shorting the live switch and sparks flew, but i recovered and its all working now. :)
