Help needed. Garage wiring | Page 6 | on ElectriciansForums
Discuss Help needed. Garage wiring in the DIY Electrical Advice area at ElectriciansForums.net
Is the installation completed now?Are you signing the electrical certificate for design and construction?Do you have Part P building regulations in N.I.?
From your only photo, you need to fit fixed metal blanks and fit the appropriate labels to the Consumer unit to complete the job. Is the electrician pleased with the install so far?
Reply to Help needed. Garage wiring in the DIY Electrical Advice area at ElectriciansForums.net
Why go to the trouble of adding another cable, which I assume would follow the same route as the other ?. Why not upgrade it. It was to try to...
thank you so much. that worked out. i ended up shorting the live switch and sparks flew, but i recovered and its all working now. :)
