Help On Using Earth As live? | on ElectriciansForums
Discuss Help On Using Earth As live? in the Australia area at ElectriciansForums.net
6ft2
Hi Im currently working for a company wiring heating systems up I have had a Job Pulled up By a QS for the company we contract for
Saying it Failed due to Earth conductor being used as a live and seriously dangerous. Ill explain , I had to run a cable in for The Heating time clock and it was a fair run , I needed Live, Neutral, and 3 switch lives ,making 5. I used 1x 5 core flex as I thought that as the timer control was double insulated then I could Sleeve the earth with Brown sleeving and use it as one of the Switch lives. Am I wrong to do this?
I have seen it done on more than one occasion, regs aside. Its bad practice, you have been pulled up over it, see it as a lesson learnt.
As far as dangerous is concerned, thats relative, and depends on the who's what's why's and where's, both now and in the future. It has the potential to become dangerous and I think thats more to the point.
Try to be honest with yourself about it, don't try to make excuses for it, cus you will be going down the wrong road.
Reply to Help On Using Earth As live? in the Australia area at ElectriciansForums.net
One of those backlight Chinese testers may have helped that’s if the tester didn’t catch fire or electrocute you. LED TV Backlight Tester 12W LED...
2 3 4 5
5K
