Re: help please on testing ground and neutral wire on lighting circuits with a multim
As Telectrix says, it sounds like you have a broken CPC there. However, this could have been broken deliberately by a previous DIYer to get round a fault and reinstating it may also reinstate the fault which could result in someone getting hurt or killed. Only a full test of this circuit prior to it being re energised will tell whether it is safe to do this. It's obviously your call whether or not this gets done.
I appreciate that you may have been a victim of some unscrupulous operator in the past but that doesn't mean we are all out to stiff you, Tesco have overcharged me once or twice but I don't now avoid all supermarkets.
The electric chair which was once very popular across the pond worked on 10 amps, you're messing with 5 or 6.
I'm not trying to belittle you, patronise you or mock your skill level here mate it's just that one of the jobs of the forum is to advise the non electrician and sometimes that has to be "Get an electrician" no matter how unpallatable that may be
