Hi All,
I hope you guys are well and have had a good day!
its actually my first time on here and I was wondering if you could give me some advice please.
i wired up an oven with a cooker switch and then cooker outlet plate. Did the continuity test and insulation resistance test and everything was ok with results. I then switched the mcb on and everything was fine. I then switched on the cooker switch and the oven went bang!!! The RCD tripped but the MCB did not so looking for an earth fault. Then I disconnected everything. I did an insulation resistance test from the CU to the cooker switch and the readings were greater than 999M ohms. i then did an IR test from cooker switch to the outlet plate. everything was then also ok. i then did an IR test on the cooker lead and the earth to line reading was 0.26M ohms suowing an earth fault. I then connected from the Consumer Unit to the cooker switch and outlet plate without the cooker connected and everything was fine no trips. Could you please help me in deciphering this problem, thank you.
