E
easysushi
Gents
Just installed CU as part of my NICEIC eval next Tuesday, got a couple of questions regarding Insulation Resistance
When doing an IR on the entire installation at the CU, connect Neutral and line together to prevent damage to sensitive electrical equipment. IR test Earth and line/neutral, the reading I'm getting is 160MOhmz is that suffient for the test. I understand that the minimum is 1Mohm but should I not be getting >299 if i have disconnected all appliances and lamps etc.
Also what do I put on the Electrical Cert if I have only done method 2 of the IR test
Cheers
ty
Cheers
ty
