T
tanglewood
Not going to argue JUD, but all sparks are different all do their own thing as long as it complies, but i would never join a cable and see it plastered over.
Absolutely not.....apart from invisible joints in the wall,you will have live cables not in a safe zone....these sort of bodges are garanteed future problems.
Chocolate blocks and tape are extreme bad practice and according to the association of Chief Fire Officers one of the major causes of house fires in the UK.Sorry I'm newly qualified. Wagos? Was thinking of chocolate blocks and tape
WAGO's are maintenance free connectors.
If you terminate cables into a junction box and that junction box can't be accessed for maintenance ie under floorboards you must use maintenance free connections. WAGO's give you this option. They are incredibly simple to install - do all the connections first before you squeeze them all into the box - simple.
The maintenance free junction boxes until 01/01/12 still also have to be accessible.
Thought it would be something like that, in which case they can be considered maintenance free and suitable for inaccessible joints now as it's only after 1/1/12 that installations *must* conform to the new regs, up until then you can choose either the original or the amended![]()
Bit harsh there Amp Dave, I know there is a blank plate in my house that has 1 phase....and nothing else behind it, no idea where the neutral and earth have gone it is fine, once I qualify it will still be fine...probably.
Cheers Malcolm, side effect of learnin most of my DIY knowledge from my grandad who was a spark about 50 years ago![]()
I most likely know him lol
