Help understanding electrical panel | on ElectriciansForums
Discuss Help understanding electrical panel in the UK Electrical Forum area at ElectriciansForums.net
New jersey
I’m not looking to do any repairs. Just looking at better understanding on how my home wiring is set up. Home was built in 94’. I’m not electrical savvy, I know some things but what would be the reason to mount a main power switch(breaker)from one side of the house yet mount the sub panel on the opposite side of the house?
  • [ElectriciansForums.net] Help understanding electrical panel
There’s nothing wrong with it, maybe the builder wanted the electricians to install a panel in front of the house so it can cover the front and the main panel to cover the back part of the house. It actually gives you options if you need anything added.
Is that 2 meters you have ?
One is labelled up PV so maybe a solar-to-grid option to 'sell back' any excess PV generation?
Yes we have solar panels. While I did mention not doing any work. I was contemplating installing a separate switch for my generator so that I can plug into my existing panel and turn off main switch in a case of power outages.
My friend it sounds like you have it under control and I hope I helped you with your questions. Happy new year
Go for a purpose built changeover switch as opposed to something requiring user input.
As above, definitely get a purpose-built generator transfer switch, and if you can get one of the automatic types.
The fancier ones will also start your generator and manage the power transfer to and off generator for you with short delays to make sure it is safe/necessary to change, and allowing a short cool-down period after returning to the utility power before stopping the generator to give its engine a longer life.
Reply to Help understanding electrical panel in the UK Electrical Forum area at ElectriciansForums.net
There is nothing inherently wrong with this part of the layout. There is another option that you may want to consider. Those supply conductors...
How did it go?
