Help: very low voltage in shower! | Page 2 | on ElectriciansForums
Discuss Help: very low voltage in shower! in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Reply to Help: very low voltage in shower! in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
The cable is way undersized. If the voltage drop is detrimental to the installation I would make a mention of it as volt drop generally is not...
It’s quite common for an electrician to criticise another’s work as you will rarely get everything perfect.
