Help: very low voltage in shower! | on ElectriciansForums
Discuss Help: very low voltage in shower! in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Hi all,
My electrical shower suddenly stopped working. I thought it was broken and then bought a new one. But the new shower still does not work. So I tested the cable, found only 55 volts in the electrical shower between live and neutral. But on DB, it is 240 between live and neutral.
It is really strange that it is just a short cable buried in the wall,how come voltage drop is so big? also in the last 2 years the shower worked quite well, anyone has any ideas?
thanks a lot for any help.
just checked the isolator, dam, the cable has melted there, i have to replace the isolator,
the shower is 8.5kw, cable is 6mm2, this should be fine, also i have used it for 2 years, but it only melted recently?
Are sure about the 6mm and i'd be inclined to replace the isolator
do you mean 6mm is not enough?
if its a decent length of run and has insulation round it your on the limit with a 8.5kw shower
not ideal.
had plumber a ring me up today asking about a shower swap a customer had bought .
"can i put this 10.5kw instead of the broken 8.5kw which is on 15m run of 6.0mm2"
answers on a post card
it has to be a loose connection
if shower cable check the board and then check the switch
failing that check shower
if none of that
you need a complete rewire
and a new substation
what a bummer
I can give you a price on all
what size breaker you got on that 6mm cable there?
correct me if i'm wrong - rough current demand of the shower
8500/230 = 36.95
CCC of cable is dependant on installation method but you'd probably be looking at most ~34A
8500/230 = 36.95
it is 40A, looks all right
Reply to Help: very low voltage in shower! in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
It’s quite common for an electrician to criticise another’s work as you will rarely get everything perfect.
If any appliance has a filter or surge protection device, you will have a device that can pass a small current between the L and E or the N and E...
