Help wiring light fittings | Page 2 | on ElectriciansForums
Discuss Help wiring light fittings in the UK Electrical Forum area at ElectriciansForums.net
Leesparkykent
Nearly Esteemed
Kent
So the Mrs went out today and brought two new light fittings...I called my electrician to put them up but unfortunately he died on the way round....Being the hero I am, I thought I'll put them up myself. I mean how Hard can it be? It's not like you need much intelligence to be an electrician...maybe just a tad more clever than a general labourer! I'm not really interested in paying one of you clowns to come and sort it out, so could one of you tell me what wire goes where? Possibly pretty sharpish before the Mrs gets home.
[ElectriciansForums.net] Help wiring light fittings
I don't mean any disrespect to the original poster, but if you want help here then you're going to have to be completely honest with us.
Your electrician didn't really die, did they?
I'm trying to be as delicate as I can, but might the truth actually be that they went on holiday?
If you can let us know, then we might be able to help, as this sort of technical information is really important to help you (sorry, us) solve your problem for you.
Okay...you caught me out! He's actually on top of a mountain in Tibet at the moment....probably booked a last minute on the promise of putting up my light fittings. Rip of merchants the lot of you!
OP turn off the main switch for everything and leave the house immediately, that green sleeving hasn't been available since 1908 so you wiring is very dangerous and could burn the house down at any moment - and can you see if there is an RCD and can you test for earth continuity in the circuit eh ???
I know it's not really in the spirit of this thread, but when presented with the picture I couldn't help wondering... "Is there a fool-proof, safe way of answering the OP's hypothetical question, assuming (a) they have safely isolated, and (b) they have no test instruments (not even a multimeter)?" There are a limited number of posibilities of what the two wires are - I can think of only 2 - so I reckon it should be possible to safely work out what they each are without use of continuity tester...
(Clearly I'm not going to post my thinking here as it'd be step-by-step instructions!)
It's simple... get the missus to hold the red and black of one cable. If she screams then that the feed and not the switch cable.....
Where is the main switch mate?
Reply to Help wiring light fittings in the UK Electrical Forum area at ElectriciansForums.net
Thank you so much for your help with this light work perfect now thank you again much appreciated
By the looks of it the whole head comes off in one unit, guess it has a driver inside of it. Ive tried to Google the Image i have, one comes up...
