Help: Wiring up emergency lighting | Page 2 | on ElectriciansForums
Discuss Help: Wiring up emergency lighting in the UK Electrical Forum area at ElectriciansForums.net
Fife
Trying to wire up emergency lighting, for some reason, this doesn't turn on at all, even when power is isolated it does not come on, so ive added pictures to see if wiring and everything is correct, tested to ensure there was power coming in when CB was on, and that there was none when it was off, any help appreciated, thanks.
[ElectriciansForums.net] Help: Wiring up emergency lighting
Reply to Help: Wiring up emergency lighting in the UK Electrical Forum area at ElectriciansForums.net
Anywhere where the normal lights are dimmed or dimmable the emergency lighting should be of the maintained type. So maintained emergency lighting...
davesparks
Thank you so much for your help with this light work perfect now thank you again much appreciated
