Help with Cabinet Shelf LED lighting | on ElectriciansForums
Discuss Help with Cabinet Shelf LED lighting in the Lighting Forum area at ElectriciansForums.net
Dave8989
london
Hi there,
We’ve got a glass cabinet/bookshelf with 4 shelves that we’d like to add some lighting to. We’ve been trying to figure out how to get 4 separate rows of LED strip lighting (~90cm)to connect together to one power source so they function simultaneously.
Can anyone help find what products we need to buy? So far it’s looking like we need the cuttable LED strip, along with 4 connectors and pins to then link to a power plug. Is there a simpler way/product?
Thanks in advance
You can buy accessory packs for most makes of led tape… which include adaptors from flat tap to ribbon cable, T shaped connectors etc… and you can branch off any number of times, as long as the total length doesn’t exceed the driver power output.
You match the accessory pack to the tape… ie, plain white will only be 2 contacts on the tape.
Red/blue/green might be 4 or even 6 contacts.
For an example….
But there are others, possibly cheaper on anazon
If you google '4nway led driver' youshould find something suitable. As mentioned make sure the driver is rated higher than the wattage of tape you're using. Normally I would use a driver with at least 10% headroom on it. Helps keep the electronics cooler which will help it last longer.
Reply to Help with Cabinet Shelf LED lighting in the Lighting Forum area at ElectriciansForums.net
Thank you for your quick and excellent response - I hadn't thought about the cables changing over time. I'll replace all three. Thank you once...
Thank you so much for your help I appreciate it alot. I learnt alot and saved alot of money in the progress kudos. Best wishes to you too.:bowing:
Hi, I am restoring an old art deco, wall mount medicine cabinet. The cabinet has an 18” fluorescent light tube on each side. Before I put a lot...
Thanks little spark. Good point but the drivers I'm considering have a sync and communication between driver function. So (as long as it works)...
