Help with led problem! | on ElectriciansForums
Discuss Help with led problem! in the UK Electrical Forum area at ElectriciansForums.net
hoppy
Liverpool
Hi
I have been to replace 2 bathroom wall lights from mr16 to 2 new led lights, however due to wiring issues, I have had to put the transformers in the loft. The lights will not
work and I believe it is due the the length of the existing 12v cables and the fact the new led lights do not draw enough current to make them
work. When I put my voltage testers across one of the transformers in the loft, the light it feeds works.
is there anything I can get to make these lights work, and would I fit it at the transformer or the fitting itself?
thanks
craig
Hi
thanks
craig
Hi
Transformers or drivers?
Cheers
Is there no way you can change them to GU10's? What sort of cable is sticking out of the wall, a piece of small 2 core flex or 1mm T&E and what CSA is it? How long is the run from loft to where the lights are? Plus, as above are you using a transformer or LED driver?
Hi
thanks
craig
What kind of voltage tester is it out of interest?
what location was the original transformer, have you come of the secondary of the transformer or have you come of the mains?
if you have come of the secondary how far have you extended the cabling ?
You do have a brilliant ability to remember everything DS! That's a compliment by the way. The series/parallel bit is obvious to me in this instance though.
I have a mate whom, like yourself, can recall detailed facts about everything he has pretty much ever read about/learned.
I don't think so, I would say I have more of an ability to refrain from posting on threads when I don't know the answers, which makes me appear more knowledgeable than people who post up guesses and wrong answers
Reply to Help with led problem! in the UK Electrical Forum area at ElectriciansForums.net
Fitted a lot of this sort of light recently, with all tests reporting back through central Dali controller(s).
nicebutdim
N
😄 It wasn't the worst I seen over the weekend. Took the kids to Cumbria zoo whilst over there, and the toilets by the giraffes just had twin...
