spicler08
Hi, any help or advice on this would be greatly appreciated...
In my kitchen I'd like to fit some some new downlights under the top cupboards and an LED strip on top of the cupboards. I also already have existing kitchen spotlights in the ceiling. So that's 3 lots of lights (hope you're with me so far!...). All of which I'd like to be connected to a single 3 gang dimmer switch on the wall. (See image attached).
Now I know this can be done but I'd really appreciate any advice on the best way to do it. One of my concerns is the LED strip, which is 10 meters in length and pulls around 50 watts - however, they only seem to come with a 12v transformer for plugging into the wall (like a laptop power supply). So what can I use instead of this to wire them up to the mains? Do I need an LED driver? All of the LED drivers I've seen are only 12-16 watts max load so I can't see how I'm going to connect a 50 watt strip to a single LED driver if the maximum load is 12-16 watts? What am I missing here? Do I need an LED driver or is there an alternative?
With regard to the downlights, I think I've got this right - I need 5 lights, each 20w, so therefore I need a 100w 12v transformer? See link below for the one I think I need. Please can you confirm if this will be suitable.
Please see images and links below for a better idea of what I'm trying to achieve. Like I say - any help, advice or alternatives would be greatly appreciated...
Many thanks
Steve
LEDs - Click here for link
Downlights - Click here for link
Downlights transformer - Click here for link
Many thanks
Steve
