Help with motor | Page 2 | on ElectriciansForums
Discuss Help with motor in the Talk Electrician area at ElectriciansForums.net
No problem, when I first read the OP it said 'cap/run/start', that was why I was confused by your post #4 and questioned it in the following post.
If an edit is made by anyone but staff after a post has been standing for a couple of minutes it will always have details of the edit visible.
Reply to Help with motor in the Talk Electrician area at ElectriciansForums.net
Do you have a test meter of any kind? if so, disconnect all four wires that go into the motor and check for a low resistance between them. You...
Well at about 9.30 last night I stripped the door card off and found the culprit, cable snapped and end off. So I spent another hour and managed...
    • Funny
