Help with new regs regarding mini trunking. | on ElectriciansForums
Guest viewing is limited
Discuss Help with new regs regarding mini trunking. in the UK Electrical Forum area at ElectriciansForums.net
Kyran
Guildford
Hi all
As yet i don’t have the new regs book so I thought i would post my question.
I have a client that manages a block of flats. Its a mid 80s block that has one entrance/exit. As you walk in the font door the clients wants the current lights to come on as walk in. which is fine i was just going to put a directional PIR up over the door as the lights need also to come on when the residents open there doors and walk in to the hall way, which is the other end of the hall way to the front door.
Now in order to get the PIR up over the door I will need to run a cable along the ceiling from the first light that has the permanent live. Normally you would could just put the cable inside some mini trunking. But I know that in the new regs there has been some changes to its allowed use, i.e. as the mini turning melts in a fire the cables drop and there have been case when is hindered firemen. Now what is the permitted way to hold a cable to the ceiling so that in a fire it does not dip down. The distance is only about 2m but it would be right over the door.
Can anyone help tell me whats can be use.
Thank you
You can get some clips that fit inside the trunking to hold the cables in place in the event of the trunking melting. Not had to fit any yet so have no idea about availability, try your wholesaler. Alternatively try steel conduit or plastic with steel saddles. But you need to check if these will meet the regs.
You should know better than to ask a relevant electrical question on an electricians forum.
So I have wasted my money buying and time looking up relevant things in the regs when I can just ask for the info on here?
Get a grip, if you want to know things buy it read it and ask questions then. Is it any wonder the trade is going down the pan with that sort of attitude?
Thank you DillB i agree with your comment. I post questions on this forum room because I believe that the people that reply are people that are in the industry, and not just one of those DIY forums that everyone just likes to comment of why you ask. We all have different levels of knowledge and experiance to share. that hopeful we can all gain form it. As long as people don't try and free load.
Reply to Help with new regs regarding mini trunking. in the UK Electrical Forum area at ElectriciansForums.net
Thanks Bennie. Yeah I have Oslo microwave sensor 2D type fittings which I was hoping to use. So permanent supply to all this would suffice? Thanks
Sorry to revive a dead thread here but should you not be installing some sort of UPS according to 710.512.1.2 ?
Recommended Sponsor News
Hi everyone,
