Help with new regs regarding mini trunking. | Page 6 | on ElectriciansForums
Guest viewing is limited
Discuss Help with new regs regarding mini trunking. in the UK Electrical Forum area at ElectriciansForums.net
Kyran
Guildford
Hi all
As yet i don’t have the new regs book so I thought i would post my question.
I have a client that manages a block of flats. Its a mid 80s block that has one entrance/exit. As you walk in the font door the clients wants the current lights to come on as walk in. which is fine i was just going to put a directional PIR up over the door as the lights need also to come on when the residents open there doors and walk in to the hall way, which is the other end of the hall way to the front door.
Now in order to get the PIR up over the door I will need to run a cable along the ceiling from the first light that has the permanent live. Normally you would could just put the cable inside some mini trunking. But I know that in the new regs there has been some changes to its allowed use, i.e. as the mini turning melts in a fire the cables drop and there have been case when is hindered firemen. Now what is the permitted way to hold a cable to the ceiling so that in a fire it does not dip down. The distance is only about 2m but it would be right over the door.
Can anyone help tell me whats can be use.
Thank you
Theres a few different ones been posted now Tel....which ones were self adhesive, as there is no way they would comply.
that's what i thought. if the s/a is just for stick them up before drilling and fixing, that's fine.
Reply to Help with new regs regarding mini trunking. in the UK Electrical Forum area at ElectriciansForums.net
Thanks Bennie. Yeah I have Oslo microwave sensor 2D type fittings which I was hoping to use. So permanent supply to all this would suffice? Thanks
Sorry to revive a dead thread here but should you not be installing some sort of UPS according to 710.512.1.2 ?
Recommended Sponsor News
Hi everyone,
