R
rick.oshea
Visited a job yesterday in an office to look at extending a ring to add some additional socket points - the existing RCD / isolator which covers the whole installation, is a Wylex 100mA 63A (fitted in the consumer unit). The installation has no 30mA RCD cover on the sockets.
There is a second consumer unit, fed from the output of the 100mA RCD in the first board - this is powering some oil heaters and the timer circuit (through a contactor).
Q. My simplist option was to replace the existing 100mA with a 30mA to bring the installation up to current regulations but wanted to check I'm not missing anything by removing the 100mA RCD and putting in a 30mA in its place - Can't fit an RCBO in the current board (not enough height room in the CU)....just checking I'm not going to introduce a problem, such as nusiance tripping because of the heating circuit / contactor on the second board.
Anyone see any problems?
Any advice would be much appreciated....
