help with rcd problem | Page 3 | on ElectriciansForums
Discuss help with rcd problem in the UK Electrical Forum area at ElectriciansForums.net
norfolk
evening all,
went to look at a mates cu the other day tt system 30ma rcd main switch tripping out randomly
earth loop to stake 150 ohms.
earth loop with everything connected 1.30 ohms.
before i did any insulation tests i did a full set of rcd tests and it wouldnt trip via my tester (mft1552) however test button did work,
so said i would change cu as replacement main switch for old cu not available,
replaced cu today with wylex dual rcd cu tested circuits as i put them back.
now the odd thing there is one lighting circuit that tests >299 l-n >299 l-e >100 n-e when i connect this it stops the rcd from tripping on test.
swapped rcds round and tried circuit on both side of cu but with this circuit connected rcd will not trip, with it removed it will.
what sort of issue can stop the rcd from tripping
for those who dont know me i am 22yrs time served with 2391
at the mo the circuit is just via mcb not on either rcd
and i am waiting to here if random tripping has stopped
thanks mark
I remember going to a job a collegue had been to..... Rcd main switch not tripping so he ordered a new one and i went to fit it on his day off.
When i went to test it, wouldnt trip either so i did my tests and found a low resistance fault between Neutral and earth which turned out to be a trapped neutral in the fused spur. So sorted that and then checked both rcds and both were fine.
Just an idea
Reply to help with rcd problem in the UK Electrical Forum area at ElectriciansForums.net
In my opinion replacing the consumer unit and waiting to see which RCBO trips is not a good fault finding technique. If the lighting circuit...
davesparks
Ok I’ll try this when I’m down
