O
Thank you for all your help I think 'distressed' is too kind! Think a visit to my local motor electrician is in order!!
Me too , look closely at switch ......Curious about the up/down switch as I don't see how you can achieve up/off/down (which I'm assuming is the operation) with only two wires.
Resistor a bit small to discharge cap , but reduce speed in one direction ?
( No liability accepted for BAD advice )
If it's a stepper motor then I can't help, but if it's a single phase induction motor I have a thought, for what it's worth.
I think the R was in series with the C and they are used to create the phase shift in the 2nd motor winding needed to start it. (It looks like a diy mod - not happy ...). So the floating R wire should be attached to the top brown wire that goes to the switch. I've attached a diagram of what I've in mind. Please remember this is a 230V motor and the wiring is clearly in a distressed state and not suitable for use, in my humble opinion.
Just revealing "GUT" feeling part of Fault finding process for others to see ...It's not using only 2 wires, the OP had missed out a Blue wire in his original diagram.
