He is a Napit member and has access to the Napit forum
Therefore he can confirm his membership by answering this question
What "make" of vehicle transporter is being discussed in the general forum section
I think you are all being a bit rude to this fellow tradesman by just pointing him to the big green book.
demkap, can I suggest instead that you use the other one, the big yellow book. Look under 'e' for electricians and call one before you do any serious damage.
If you are indeed an electrician then I apologise and take back the above comment. I assume you have done work in your own house so turn a few more pages and try under 'f' for fire insurance.
mate i am trained! and i am nappit thank you
You may have dropped yourself into the soft brown stuff with some of your questions.
What's your call sign/avatar ?....... and don't let the nemesis of the 5DW find out who you are
Shot down in flames eh?
Why not ring NAPIT tech support and ask them?
This is an interesting point.
All registered Electricians in England and Wales are listed on the competent persons scheme website.
Could Dan use this as some form of "access right" to people claiming to be registered Electricians to check them out? a sort of half way house to the Electricians Arms??
hi there just wondering any calculations for working out cable size. so example i have a 9.6kw shower what breaker and cable size do i have to use?
also with wired in smoke detectors can they be wired say off a socket circuit or a fused spur in use or does it have to have its own circuit?
thanks
Did u not post this thread in the middle of a lighting circuit thread :/
help
Thread Tags
demkap,
Octopus,
TrueNAS JBOD Storage Server
