Help! | on ElectriciansForums
Discuss Help! in the Auto Electrician Forum area at ElectriciansForums.net
M
Mxjack6
Hi, i've just installed a dab pioneer headunit into my 1979 mini van.
i wired it too the igntion so that it turns off when i take the key out
however eachtime i start it back up i have to reset the clock and retune
it. Theres is a second wire too connect too the battery so the clock never
needs resetting or anything. Do i need a fuse in the wire between the
headunit and the battery? There is a number 10 fuse sticking out the back
of the headunit so would that mean i could just wire the radio too the battery
without another fuse?
thanks
jack
Usually the fuse size would be according to the size of the wiring but if there's a 10A fuse at the head unit then just make the in-line fuse the same size.
Reply to Help! in the Auto Electrician Forum area at ElectriciansForums.net
  • camperVanGuy101
  • Australia
  • 2
  • 761
