Henley Block between meter and main switch | Page 2 | on ElectriciansForums
Discuss Henley Block between meter and main switch in the UK Electrical Forum area at ElectriciansForums.net
H
hutch6447
Hi quick one if you come across the meter tails coming from the meter to a henley block then from henley block to main switch on consumer board, if you replaced that consumer board would you still need to remove main fuse or could you just disconnect from henley block and leave fuse intact? cheers thanks.
I have just booked with the supplier (British Gas) to fit an isolation switch 10 mins ago booked over phone £31.42. Two weeks lead time but if you plan ahead a little not bad.
Personally, I prefer to know that I am safe and ruddy bollards to anyone who would like to argue this fact. Tampering deserves the consequences but safe isolation is justified "In my very own opinion"
I ALWAYS reseal using the braided steel seals that anyone can purchase thus leaving the installation safe. I do not agree with those who pull to achieve safe isolation and not replace seals as this COULD lead to a fatality.
Now obviously I would not undertake such work in front of someone that works for the DNO but if they turned up whilst I was working than I would show them that I have adequate seals to make safe afterwards.
Electricity kills, why take the chance? :thumbsup
The Electricity at work regs do require that we do not work live. Safety first.
Do a risk assessment first before working on live equipment. Is there a safer way of disconnecting, Yes ! Remove the main fuse on no load. As far as I know nobody has been fined for removing the fuse as long as you are not trying to steal electricity.
What worries me is not someone being fined for pulling a fuse, it is what can go horribly wrong if there is a fault on the cut-out while attempting to pull it or re-insert it.
Really if you don't have some appropriate PPE (gloves, face shield, clothing that won't melt and stick to your skin) and an idea of what arc-flash means, keep well away!
Reply to Henley Block between meter and main switch in the UK Electrical Forum area at ElectriciansForums.net
Hope everyone has had a great Christmas and here’s hoping we all have a better new year coming our way ! Remember our riches aren’t measured by...
Obviously you need to check the means of earthing, Ze, and polarity no matter what for the EIC. As above, if anything looks dodgy then EICR is a...
