H
hutch6447
Hi quick one if you come across the meter tails coming from the meter to a henley block then from henley block to main switch on consumer board, if you replaced that consumer board would you still need to remove main fuse or could you just disconnect from henley block and leave fuse intact? cheers thanks.
