here is one for you to argue about | on ElectriciansForums
  • Thread starter DurhamSparky
  • Start date
  • Replies 40
  • Views 4K
Discuss here is one for you to argue about in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
DurhamSparky
Currently Undertaking a rewire of a empty property
PME
No Gas
Water inlet is plastic and water distribution around house is plastic "but the stop tap is metal"
i have no intention of dragging any bonding cables to the main water incomer!!
please please please argue with me some one!!
lol
PME
No Gas
lol
For God's sake, be professional man and bond that tap!
I've seen it done in a newly refurbed house last year.
PME
No Gas
lol
Sometimes you can be a tease ;)
The pipes may not be conductive but unless it's extremely pure the water in the pipes will be conductive, so that might need bonding.
You could do, or you could just bond the boiler, or each tap. You'll need to bond every tap though, because they won't all be linked when the tap is off.
Or you could install a bit of metal pipe to bond to.
now we just been daft!!!
oh i was hoping some body would argue against me not bonding....
guess i will have to just bond the TV aerial as it says must be electrically earthed..!
Last one like this I ran bond to boiler as all pipes here are copper.
I can only see this was a box ticking exercise but done none the less.
If you cant do it properly would you like me to come up there and show you how its done?
Reply to here is one for you to argue about in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I like your way of thinking.
loz2754
L
Yes the first bit is just standard wiring, TNS lead cable into cut-out, cut-out to meter, meter to DP isolator, top of isolator is sealed as per...
