here is one for you to argue about | Page 2 | on ElectriciansForums
  • Thread starter DurhamSparky
  • Start date
  • Replies 40
  • Views 4K
Discuss here is one for you to argue about in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
i was waiting for you you Mr Brown...!!
unfortunatly there is no boiler...!! it will be fitted out with electric water heaters and crap like that.... lol
if you wish to take a steady drive to the land of the gods i will open you with welcome arms and a sharpened knife..!! oops lol
So, what about exporting PME,
I have been asked by some chap called Ivor Biggun to fit 3 phase electric fences to kill foxes.
Can I export my PME to the chicken coup or do I need to TT it?
Water isn’t very conductive, otherwise I’d have been blown up many years ago. 2.6MW being feed through water-cooled cables and coils worked fine for me.
But as it’s domestic you should really run a 10mm to the tap ! ! ! !
I would run the cable anyways, especially if the floor is gonna be up.
Plus, it should still be bonded if the install is all copper, even if the incommer is plastic.
Come on Steve, this is day one stuff they would have taught you on your fast track :D:D
How secure is the reservoir...?
A terrorist could dump aluminium sulphate in reservoir, making its way into households, this, coupled with the latest solar flare could cause the plastic to crack et voici your extraneous part is realized.
Or...
Maybe the new people moving in breed electric eels, a few might escape from the bath overflow, start their own colony and ...bingo
Or...
Maybe a rogue driller of thermal heating boreholes is operating in an area of granite, the radon seeps into your water via a leak.....
I think I need some friends of my own.
or run in a length of earth sleeving and tie both ends. fill sleeving with water so it's conductive.
Reply to here is one for you to argue about in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I like your way of thinking.
loz2754
L
Yes the first bit is just standard wiring, TNS lead cable into cut-out, cut-out to meter, meter to DP isolator, top of isolator is sealed as per...
