Hidden Kitchen Sockets | on ElectriciansForums
Discuss Hidden Kitchen Sockets in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
C
Colin_K
Just wondering if somebody can advise, as I'm not Part P approved (just 17th). A neighbour is in the process of redesigning his kitchen and now has 2 double switched sockets behind a fixed unit which feeds a fully electric oven, hob and microwave. The oven, hob and microwave being permanent fixtures. These sockets appear to be part of the ring main. Would I be correct in saying that they should be feed from an accessible switched fused spur instead?
yep your right.
you should be able to get to the sockets to isolate the appliances without the need to remove the appliances first.
so SFCU for each appliance is probably a good idea. or relocate the sockets into a cupboard so there accessible from there
Just as I suspected. I'll pass that on to them. That'll cost them a few quid more !
Many thanx.
Not too sure about what current the hob draws, cant be much as it has attached cable with moulded 13amp plug on it.
Missed the bit about the hob !!
Only 10KW on a plug top
It will be okay :)
Lol
- - - Updated - - -
And your 17th and you didn't know this either ?? :S
10KW / 230 Nominal Voltage = 43.47 Amp
Allowing for diversity 10 amp Plus 30% of remainder
43.47 -10 = 33.47 @ 33% = 11.04 +10.00 = Total 21.04 Amps.
Been retired 12 years and have yet to see a Plug top that can accommodate 21.04 amp rated Flex.
Read and comply to the regs.
Having 17th Edition does not and will never make you an electrician.
You need the equivelant of the old A,B & C. certificates.
Part "P" to technicians ike myself means partly qualified, ie the 12 week wonder
Except part P is not a qualification......thought you'd know that being a technician and all.
Reply to Hidden Kitchen Sockets in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
When you say plus kettle, does this indicate you are needing 13A socket/s on the island and a hob supply? and then an oven supply on a tall...
