Hilmor pipe bender it's mine all mine! | Page 3 | on ElectriciansForums
Discuss Hilmor pipe bender it's mine all mine! in the Electricians Chat - Off Topic Chat area at ElectriciansForums.net
what do you mean by a screwed down corner? if you mean a pre-made angle or box.surely that will have an inspection plate so you can thread cable .
Do you push it, pull it, rod it or thread it
All bends, very rarely a jointed bend. It is very difficult to get cables around a jointed bend. The pic is 20mm conduit and the most interesting challenges with bends is screwing them into the joint boxes as you have a massive crank handle so to speak, so how do you wind the thread as you need plenty of space to do it? So that is why people use jointed bends and of course it is easier to measure and get right as opposed to making a bend fit to two different points. I use a piece of crate packing tie, you know those bands made of some kind of nylon? Just use a long one. Very good at snaking around the bridge even in the picture. And of course you really have to consult your conduit/cables tables to make sure before you start you have the right amount of cables allowable and doable!
[ElectriciansForums.net] Hilmor pipe bender it's mine all mine!
screwed down corner
Because they are cast corners the quality means there are loads of bits that obstruct the cable going around. When you remove the inspection plate there is not a corresponding hole it is filled in with badly cast metal, you could not even get anything in there to get hold of a cable on the short bends anyway, the sweeping bends are better.
Just the day to be in an insulated metal box Vorti, I'll bet it got a bit moist in there. Lovely job. You need to nip back and take a photo when all the furniture is in and the workers are there - one for the NVQ!
Thank you Vortigern.
Beginning to understand the gap between C&G2365 and the job. Anything involving forming materials (pipes, conduit etc) is as much an art as a skill. I plumbed a couple of kitchens with copper and a spring more for the experience than any objection to PEX. Took me AGES!
Tbh, I really enjoyed that job it is most satisfying the ring of the threader and grunt of the bender, mhm that sounds bad doesn't it. Anyhoo it was nice to do instead of miles of plastic conduit all the time. You know something that gives you satisfaction doing it, oh and money!
I remember being a skinny 21 year old and having to bend 32mm conduit for an installation, thank god for the length of scaffold pole that I liberated.
Reply to Hilmor pipe bender it's mine all mine! in the Electricians Chat - Off Topic Chat area at ElectriciansForums.net
That is very cool. It would be the end user software that would make that the absolute king.
    • Winner
    • Informative
