Hob cable outside then in | Page 6 | on ElectriciansForums
Discuss Hob cable outside then in in the UK Electrical Forum area at ElectriciansForums.net
Swansea
Evening All another odd question (I love my customers)
There’s no 10mm or 6mm cable in their kitchen, apparently when it was wired there were all 13amp eco appliances. Anyway a new couple have bought it and want a 5 ring hob installed but the kitchen is done to a high standard so they don’t want trunking or walls chased (kitchen in single story extension. The board and job location are on the outside wall. Can I run a 6/10 mom cable through the wall outside the back inside for for the hob connections obv the cable would be aremourd or SY. Is this doable or is it a case of no can do
Not sure why everyone seems to have found this so difficult to understand. I have a similar issue. We're moving our kitchen and running a 20amp cable to our new hob means taking up a wooden floor which would be very expensive to replace. It could easily go via the ceiling (no upstairs carpets yet), down the outside wall and in again just behind the hob. Did you find an acceptable solution?
[ElectriciansForums.net] Hob cable outside then in
Reply to Hob cable outside then in in the UK Electrical Forum area at ElectriciansForums.net
When you say plus kettle, does this indicate you are needing 13A socket/s on the island and a hob supply? and then an oven supply on a tall...
