Hob cable outside then in | Page 4 | on ElectriciansForums
Discuss Hob cable outside then in in the UK Electrical Forum area at ElectriciansForums.net
Swansea
Evening All another odd question (I love my customers)
There’s no 10mm or 6mm cable in their kitchen, apparently when it was wired there were all 13amp eco appliances. Anyway a new couple have bought it and want a 5 ring hob installed but the kitchen is done to a high standard so they don’t want trunking or walls chased (kitchen in single story extension. The board and job location are on the outside wall. Can I run a 6/10 mom cable through the wall outside the back inside for for the hob connections obv the cable would be aremourd or SY. Is this doable or is it a case of no can do
Basically asking can I run the cable from the board inside, through the wall clip the cable to the outside then bring it back in where the hob location is and connect up. So basically the cooker feed with run outside then back in
Despite all the confusing replies I think the simple answer is;
YES.
But give consideration to the type of wiring/method you in tend to use!
6mm t+e run through 25mm conduit on the external section would be simplest. Don't really like t and e in conduit, but no point adding unnecessary joints for sake of it, and twin will be easier to route on the internal sections.
I have done exactly that on a recent job where new owners were buying a dual fuel range, conduit was the best option for that particular job.
Reply to Hob cable outside then in in the UK Electrical Forum area at ElectriciansForums.net
When you say plus kettle, does this indicate you are needing 13A socket/s on the island and a hob supply? and then an oven supply on a tall...
