I have just installed a Honeywell Accenta G4 system. All ok apart from 2 queries:
The entry/exit zone 1 is a PIR (there are no door contacts on my system, just 2 PIR's) It is set to zone 1. The second PIR is in the lounge.
The system will set ok, but only after I am out of the range of the zone 1 PIR (exit). I think it should ignore the PIR during the exit time period but displays the message "setting error" and halts the timed exit until the PIR is clear.
The second query is the quick setting of the system when exiting the premises via a single keystroke without having to input 4 digits. Can not see in the book how to set it. It says it can be set to do this by the engineer (in this case me)
Thanks,
Frank
Thanks,
Frank
