Honeywell alarm | on ElectriciansForums
Discuss Honeywell alarm in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
P
P-Courty
Been doing a job on a shop and they have gave me a honeywell alarm to put it but the wiring diagram that came with it is an accenta one and doesnt relate at all, there is also one from honeywell but even that doesnt relate. I have wired all the sensors already as i have done many before but the last time i did a control panel, bell box and door contact was a long time ago so don't want to mess it up. Is there any chance anyone has a wiring diagram for it?
cheers guys.
they are all pretty straight forward with regards to zones and if you have a new bell box that usually has a booklet with wiring diagrams for that bb to many differant panels , what bit are you struggling with in particular
ive got the instructions and leaflets with it but they are useless they have all kinds of drawings for different panels but nothing that explains the one ive been given
Ok 1st things 1st, you need to find out exactly what panel you've got. Can you post up a link to the manual you've got or a picture of it ? to give us something to go on. The Accenta is a Basic 8 Zone closed loop panel with Global Tamper so is very easy to install, the only thing you really need the manual for is the programming section. But before you install the panel in a Shop i'd make sure that the Customer is informed in writing that you accept no responsibility for it.
Look for 4 connections on the control panel, all next to each other, T A D B.
There is a factory fitted link across T & A, this is the bell box tamper circuit.
D & D is the bell/siren output.
T is the tamper return connection.
A is the negative siren connection.
D is the 13volt supply to the siren.
B is a switched negative trigger to the siren.
Connect "T" to the siren tamper, usually marked "TR", (some siren units have 2 options, you want to use the -ve if this is the case).
Connect "A" to -ve hold off, (when in use, there is a negative circuit between "T" & "A"), remove the link at the control panel.
Connect "D" to +ve hold off.
Connect "B" to trig(ger) at the siren.
The "A" & "D" connections supply the siren unit, "T" is a signal connection which should be at 0volts, otherwise a tamper fault will exist. "B" is normally at 13.6 volts, until an alarm condition occurs when it is switched to 0volts, providing a negative for the siren's sounder to work.
I do not wire the strobe seperately, because an alarm that has been "set off" and not reset would be advertised to a potential thief as such by a silent siren unit with a flashing strobe.
good luck
MikeP
It really does not matter what the precise model of the panel is as long as it's of the the older panel's based on the old ADE layout, ie Accenta or Accord or even the ID panels, (Ultimate, Karizma, etc), the siren connections are the same. For that matter, the siren connections on almost every intruder panel conform to the principle of a supply voltage for a siren hold-off, a tamper return, (which is derived from the -ve side of the hold-off), and a trigger, (which is a switched -ve), which provides a connection for the current through the sounder, (in an alarm condition).
It's quite simple,
MikeP
Reply to Honeywell alarm in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
hi yes i agree its a final pir circuit with 30 seconds entry and exit programmed in no other detectors on route to rkp tried a different...
That will only count when the alarm is active o/p said tamper. O/P doesn't seem to be in any rush to give more info, so I doubt anyone else will...
