Honeywell alarm | Page 2 | on ElectriciansForums
Discuss Honeywell alarm in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Exactly!
the hold-off voltage is applied to the siren's control electronics, (used to be a relay in ancient days), if the voltage is removed or disconnected, (Burglar Bill severs the bell wire), there is an integral ni-cad in the siren unit which provides energy for the sounder to work. Opening the tamper switch on the unit, (removing the cover or levering the unit from the wall), has the same effect.
For a thorough understanding of the siren unit consider developing a wiring diagram from first principles using a change over relay.
MikeP
Reply to Honeywell alarm in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
hi yes i agree its a final pir circuit with 30 seconds entry and exit programmed in no other detectors on route to rkp tried a different...
That will only count when the alarm is active o/p said tamper. O/P doesn't seem to be in any rush to give more info, so I doubt anyone else will...
