Honeywelly9420 sundial rf pack 2 | Page 2 | on ElectriciansForums
Discuss Honeywelly9420 sundial rf pack 2 in the UK Electrical Forum area at ElectriciansForums.net
Norwich
I have just installed the above heating system controller on a Y plan all seems to work ok but the programmer is saying no signal and rf icon is flashing. The thermostat is coming in and out on tempeture, programmes are ok but this “no signal” is bothering me any ideas please
Thermostat is a DT92e
Yea as Lee says. Unbind and rebind and do a signal check first thing to do.
There pretty good but there’s a few things that might upset it like large metal objects(boiler) too close to prog or stat, foil backed plasterboard celotex etc. blocking signal
Had absolute murder with a Honeywell Evohome once and turned out to be interference from a Sonus speaker syestem.
I have disconnected batterys in stat which seems to reboot it. And turned power off of programmer to reboot that. It runs fine for a while but reverts back to no signal.i am using a wired cylinder stat which is not honey well would that make a difference?
I have noticed that if I go from constant hot water to constant heating switching the hot water off the 3 port valve is not moving!
Just moved temp on thermostat to below the room temp and boiler cut out. Put it up again and boiler comes on so rf is working. Yet programmer says it is not! Begging to think there is a fault in programmer
With all due respect BT and electrics are different.
When I wire a heating system I run through a series functional checks when ive finished, which involves turning stats up and down and watching values switch over.
If I suspect there is a problem with the room stat is prob link it out.
Have you connected the programmer up right ? Have you got call and satisfied (also refered to as "make" and "break") right way round on the Cylinder stat ?
Is the polarity right on your receiver ?
Out of interest have you wired the complete heating sytem in flexible cable ?
Reply to Honeywelly9420 sundial rf pack 2 in the UK Electrical Forum area at ElectriciansForums.net
You need a wi fi switch that is compatible with your switchbot thermostats. Remove the SCR, use the neutral and live to power the wifi switch, and...
Thanks davesparks. Looking at the diagram on the driver that's what I interpreted too, but I heard somewhere that the DALI system doesn't like...
